SO I'm curious what people are using for power on a single or dual A123 with one Rx and a TechAero IBEC for a 35cc 3D plane. I've done a single 2500 A123 to a modified Miracle switch (for the 3 wire version batteries for the balance tap/pwr feed) on a Cub.
My concern is will that be enough wire to support 5-6 digital servos, and the TechAero on a 3D 35cc plane? I cant seem to make up my mind.... debating:
2x 1100 A123 on a booma pin flag switch.
1x 2500 A123 3wire to a single switch with one 18g or (two 20ga) leads.
Keeping in mind this is for one Rx only and I think two 2500's are overkill. I don't have any data supporting the thoughts in my brain, hoping someone else has experience with this...? My perfect outcome is a solution that supports the high drain of 5-6 thirsty 1270/7955 servos and a Tech Aero. Thoughts?
