Sunday was a good day for a few shenanigans with my son. The best video didn't get captured. But well, yeah...ya'll get the idea.
			I'm GREEN with envy!
Very nice.... Looks like it was well taken care of. Hope it flies really well.I bought this a bit older 3DHS Edge 540 a few weeks ago. Bought a DLE 35 and Hitec Servos and misc to finish it off. It is ready to get engine running and initial adjustments. Hopefully get to put a couple flights tomorrow.
Now that you mention the battery capacity, it is a question I always ask myself when I see the size or better said the capacity size of the battery's people are installing in there planes. Of all my planes I have never been able to use more than 380 mAH per flight and that is in a 40% plane weighing 40 lbs. at 5 flights the most you will need is 3000 mah. That leaves you with a 30% plus safety margin so two 1500 would be sufficient or at most 2 -2000 mAH packers. I must say spending sometime at the 3 D line at JoeNall most the planes had 2-5000 mAH packs. But a few were running what I believe to be some what better and one of them was Jase he was running two 1300 mAH packs I believe. Or am I missing something.The weather looks to be a bit crappy tomorrow, but I am going to chance it anyway. I think the Pitts is needing a little more wringing out. Changed the weight to get a little bit more on the tail and had to do a minor thrust adjustment. I was also quite impressed with the battery usage from the initial Maiden flights. As many of you may remember, I went with twin PULSE 2s 3600mah Lipos to operate everything including ignition on the "dub" 70 twin. My goodness, she is a little miser. Barely 400 mah used on both packs for three really good flights. Is that about normal for Lipos guys? I am used to the Fromeco Lion Relions I use in all my other birds.
Wow I thought the 20+ were having here was bad, 50 miles an hour would blow your plane away before takeoff.30 to 50 mph
