Monokote trim solvent works great on the edges for Ultra over Ultra. As for the bubbles, I've discovered a little technique. After your base coat is on, and sealed down "REALLY" well with about 225 degrees heat. (Shrinking the base layer with heat gun at this point) Turn down the iron to about 125 to 150 degrees and use your heat gun to shrink your base coat while ironing the base to insure it is down! Allow your iron to cool to no more than 150 degrees. Just enough to warm the adhesive. Start in the center of your trim (top) coat and work to the edges. Once the trim is down good, your iron heat can be increased to seal your trim so it won't come off. The air bubbles that are created when laying Ultra over Ultra are the gasses that are released due to heat activating the glue. If the trim is sealed really well before the final heat is applied, the gas vapors can not create bubbles. Perhaps others may have their own technique, this is what works for me.
