Madinpensacola
Not sure I get your logic. The HS-M7990TH is only 10 more grams or 10% heavier than a 2270. Two 2270s at 140 grams are heavier than the 79 grams of the Hitec.
I think the Hitec may be a negative because of the lack of weight if you like to hover around and generate good tail inertia for pop tops. But in a plane of this size a few grams here and there most likely will not impact CG that much.
The servo tray ALONE weighs 120 grams or 4.3 ounces or 1/4 pound. With the servo its is a bit heavier than a 2 servo setup without a tray. Hitec plus tray is 199 grams.
