3dNater
3DRCF Regional Ambassador
There is nothing wrong with running 6s.  I don't think anyone is attacking it... it is well documented that 6s packs will work fine.  The only point being made here is that the higher voltage systems are more efficient and don't have to add weight.
Since there are so many numbers flying around though, this has really gotten down to the nitty gritty. [MENTION=2280]Dr. Gonzo[/MENTION] has posted 75A repeatedly for the max amperage of the 12S setup. I would like to know where that number is coming from. Aeroplayin's highest amp draw was 68.6 Amps and we can see that the calculation is affected a great deal by the difference.
68.8 Amps x 33% power =22.704
2600mAh x 70% safe capacity =1820
1820mAh is 1.82Ah
22.704 Amps divided by 1.82Ah = 12.47C
60 minutes divided by 12.47C = 4.8 minutes
By using [MENTION=95]Aeroplayin[/MENTION]'s amp draw number you gain 1.2 minutes of flight time. So I guess the lesson to be learned is... prop it right and it works out nice. Get greedy on the power and you get a short flight time on either system.
The place where you win with 6s is if you have the packs already, but I'd probly spring for the 12s setup if it were me because I don't have any 6s 5000 packs. But on the other hand, if I had 6s 5000's that were being used on another size I might just spring for the 12s setup anyway because I like lots of power and cool running motors
  The 6s packs you have are a sunk cost, meaning they should not have a bearing on your decision if you view going another direction as being the better long-term choice.  The fact they can be used in another size airplane is a big plus.
1820mAh is 1.82Ah
  I want to see this thing fly post stall.
