Extreme Flight 88" Edge -- now with EXP sized horizontal stabs
Bigroger
Gary,
what size swb arms did you end up using on the elevator on the Edge EXP?
I have the swb 2" but wondering if I need all that throw, or maybe come in one hole which is about 1.75" I think.
Gary,
I used the 1.5" that I had, but just ordered some. 2.0" to install.
-G
Bigroger
DA70 on the edge
haven't flown it guys, but a few pics and a video of the first start once its cooked from Vimeo.
[video=vimeo;77379158]https://vimeo.com/77379158[/video]
RKEstes
Awesome Bigroger! I am starting on the same combo. The plane is on the build table and my engine arrived today. I was surprised to see that it did not come with any standoffs but that is completely understandable. I was wondering if you would mind telling me what length your standoffs are? Thank you!
Bigroger
No problem Bro.
I went with secraft 20mm standoffs and it's sweet.
I did run into a drama today on maiden.
Was getting 6650 rpm peak in the backyard when I shot that video, with the cowl off.
Today at the field I could only get 6100rpm and she sounded sick.
Took the cowl off and back up to 6700rpm.
After 5 flights today I'm now getting 6970rpm and it's ripping the 24-10th nicely.
Not sure why I'm getting this effect with the cowl, but I bet it's to do with air to the carny.
I'm going to open a carb hole in the cowl to see how that goes .
Sounds to me like the cowl might have some pressurization issues? Do you have a good air exit and such?
Bigroger
I think so.
See pics.
But no hole for the carby.
I think so.
See pics.
Hey Rog!
On cowls with really large openings like that, I've seen people put a little lip on the forward edge of the opening, as this helps create something of a vacuum effect to pull air entering through the front of the cowl out of the bottom/back
