HuckinHavoc
Well today I preformed a major screw up. The magic smoke escaped from my CC BEC and my CC Phoenix Ice Lite 50A ESC. I am starting to put BECs on all of my planes because I have started using digital Savox servos with a Spektrum RX. Without the BEC the Spektrum RX wants to brown out so I am getting around that by using an external BEC. This is only the second one I have hooked up.
I basically soldered the BEC battery leads onto the ESC battery leads. I hooked my motor up to it so I could check the rotation of the motor. I then plugged a 3s battery in, but I forgot to plug the servo extension wires into my RX first.
I am not sure if not plugging the servo leads from the BEC and ESC into the RX is what made them fry or if it was my wiring. I am thinking that it was probably not plugging them into the RX but I do not undestand why that would make them fry. Here is some pictures of my wiring in case that is the problem.
