For Sale Razorback Fueler
The Razorback Fueler is Offered in 2 Different Sizes and 3 Different Colors
* 2.5 Gallon and 5 Gallon
* Colors Red, Blue, Yellow
* 6 to 12volt Reliable geared pump works with Gas, glow, smoke, and jet fuel
* Our unit is different from most on the market. It is made of a Heavy duty race fuel utility jug with a big neck and no fittings are mounted in the lid. Making filling the Jug Simple.
* With our unit we give you the Choice to use your own battery. As most Rc Hobbiest have a 6 to 12 volt battery lying around that can no longer be used in a model. We recommend that you run the Pump with a 3cell Life or a123 battery as the pump life will last longer at 9.9 volts than running 12 volts. We also recommend you do not charge the battery while attached to the can. As this can be very dangerous and cause a fire if something went wrong. Plus you using your own battery helps keep cost down and make our unit more affordable thank others on the market. The pump will also work with Nicd, Nimh, lipo, Lion batteries, We just recommend Life or a123 due to robustness
* With our unit another difference than others on the market. Is our pump only runs one direction, but you are still able to fuel and defuel you Model. This is done to keep from back washing the pump filter which will save you many of dead sticks later in the flying season
* Our unit also has the option of having an Over fuel catch line at no extra charge. Just Let us know in the note on check out that you would like this option and we will take care of it
* Units are made upon Order. Please allow 3-5 days for shipment depending on inventory and other orders, Red Cans are stocked. Yellow and Blue are special Order but I can have the can in two days if order is made by 9 am
129.99 plus flat rate shipping of 25.00
