#44210 : Hitec Battery Buzzer : $9.99
http://www.servocity.com/html/battery_buzzer__44210_.html
Hitec is pleased to introduce their new Battery Buzzer - a compact, convenient, low battery voltage alarm. No longer do you need to wonder about your flight pack condition. The Battery Buzzer warns you when you are getting close to the end of your flight and it is time to land. With a programmable voltage threshold, you decide how much advance warning you want when the alarm sounds. Not only does it protect your model from unexpected off-field landings, the Battery Buzzer also protects your battery from over-discharge, maximizing your investment. Both inexpensive and lightweight, the Hitec Battery Buzzer is a must have accessory for all your electric models.
Specifications:
High pitch warning sound
LED status indicator
Input Voltage: 7.4 ~ 16.8 Volts
Voltage Selection: 3.2V / 3.3V / 3.4V / 3.5V / +/-0.05V
Battery Type: 2 ~ 4S LiP
Dimensions: 1.97†x 1.10†x 0.49â€
Weight: 0.39 oz (11g)
Get your Battery Buzzer at ServoCity today! http://www.servocity.com/html/battery_buzzer__44210_.html
