New Flight Power Batteries
garlandk
I recently got in several Flight Power packs to use. I must say I am very impressed with the quality of the products. The new 70c packs are perfect for any 3D airframe. I am running the 3800 mah 6 cell 70c packs in my prototype Yak 55M. I compared the packs to the older Flight Power packs and must say I can tell the difference between the two! I am having full performance throughout the whole flight.
Few other changes made to the packs is that they now have the JST XH balance plug. This helps out a lot considering I no longer need a adapter to charge my packs with my chargers.
A new deans style connector comes solder on the battery pack. The connector is called the Star Plug, they have fit any old deans connection that I have tried.
The star plug is neat because you can easily unclip the cover that covers your solder joints to check on the solder.
XTS Connection:
Star Plug:
Other batteries that Flight Power has.
FPRX
Cell Counts: 2S through 2S2P
Capacities: 1300-4200mAh
Balancing Plug: JST XH (all packs)
Charge/Discharge Plug: (2) universal connectors (all packs)
Maximum Charge Rate: 1C
FP25
Cell Counts: 1S through 6S
Capacities: 125-4000mAh
Balancing Plug: JST XH (2S+ packs)
Charge/Discharge Plug: micro (FPWP2022-2063) Star Plug* (all others)
Discharge Rates: 25C Continuous/50C Burst
Maximum Charge Rate: 3CFP30
FP30
Cell Counts: 2S through 6S
Capacities: 450-5000mAh
Charge/Discharge Plug: micro (FPWP3042, 3043) Star Plug* (all others)
Discharge Rates: 30C Continuous/60C Burst
Maximum Charge Rate: 3CFP50
FP50
Cell Counts: 3S through 6S
Capacities: 1800-5500mAh
Charge/Discharge Plug: Star Plug* (all packs)
Discharge Rates: 50C Continuous/100C Burst
FP70
Cell Counts: 3S through 7S
Capacities: 1300-5500mAh
Discharge Rates: 70C Continuous/140C Burst
2 Year Warranty!
Flight Power Packs used in the new OMP Yak 55m 60" Airframe
Flight Power Promo Video:
Visit Flight Power's website:
www.flightpowerbatteries.com
Meet Flight Power's Flight Team:
www.flightpowerbatteries.com/team.html
bob_nj
Can you explain the maximum charge rate designations in the 30 and 50 Kevin?
That is 3CFP30, and 3CFP50
Thanks
Max charge rate is just that. The maximum allowable amperage for charge rate. 1c where c equals capacity. Take a 5000 mAh pack. 1c is 5A charge rate, as there is 1000mAh is 1A. 2c is 10A charge, 3c is 15A.
Thanks
I was referring to the "FP50" that isn't listed in all of the packs
Actually, it is. It is listed above in the description.
I looked 3x before I made this post, just to be sure that it was the correct pack I was looking at.
Will it hurt anything by being charged at a lower rate?? Not at all, it will just take longer to charge. Thats all.
