inverted practice
wedoitall
Member
just got finished doing blenders and see that it looks better exiting inverted harrier. is there any good exercises i can practice to fly inverted better. should i just spend a day or so practicing inverted harriers or is there something else i can do to get better at inverted manuveurs?
thanks in advance for the help.
rcdude07
practice practice practice. Not comfortable in real life with your plane and altitude, practice on the sim.
Steve_B
IMHO you need to get totally comfortable with 'normal' inverted flying before thinking about inverted harriers. Just spend as much time as possible doing inverted circuits and figure eights, simple aerobatics like loops and rolls starting and finishing inverted.. etc. Then try to coordinate turns with rudder when inverted (hard because rudder is opposite). Once you are totally comfortable then think about inverted harrier.
djmoose
I agree with Steve_B. Spend a lot of time flying inverted. Until the opposite rudder is second-nature...then start with harriers.
wedoitall
Member
thanks guys! i have been dedicating a portion of sim and Real flying to just flying inverted just like you guys mentioned. the coordinated turns are my bottleneck at the moment.
djmoose
I don't know if this is a good idea, but it has worked for me. I think of pushing the either the tail or the nose (whichever is closest to me) with the rudder stick.
wedoitall
Member
yea never thought of it that way, i think thatll help alot. the hardest part atm for me is the coordinated part of turns with rudder, aileron, and elevator. so used to moving the sticks in the same direction with up elevator but your way i think will help alot, think of pushing closest end. i did something similar when learning KE flight
Ohio AV8TOR
Just Do It
All great info above, use a sim and get yourself a foamy to practice on first. You are just a half roll away from back to normal flight, keep that in your mind for a bailout.
djmoose
For KE flight, I used this: Belly facing you, rudder stick always goes to the nose. Canopy facing you, rudder stick always goes to the tail. Never think of just the combined motions of the sticks because when you start doing inverted-to-KE....they're different. I thought it would be best to learn where the rudder goes in any orientation. (also because you shouldn't have to ever think about your ailerons...they never change)
wedoitall
Member
this has seemed to help me also. dont really have a problem with steering. its just getting used to up is up and down is down on the elevator but the last couple of days that has gotten alot better. (after a couple nose take'n dirt naps)
