Help with first Gas motor
Hey guys need a little help on gas engine stuff-newbie at this. (Although I am fairly fluid with gas engines, weedwhippers, lawnmowers, lots of nitro engine experience)
For the choke lever, do you typically reach in and flip it...have a separate pushrod sticking out of the cowling? Seems like its a ways back to reach in and flip.
And the OS 33 can take unregulated 2s LiPo right?
For the kill switch, I got an electronic one, but should I set up the linkage to kill it with a throttle cut? What is the general linkage set up?
How do you guys typically break them in? I have a break in prop-Xoar 18x8
I am putting a smoke system on too....on the stock Os muffler. I bought a brass nipple, where would be the best place to put the inlet? I will wrap the hi temp tubing around the muffler to heat the oil.....i have that anti siphon thing, and filter...etc. Sullivan sky writer.
Also what is YOUR starting procedure?
Thanks guys...:)
Wow thanks gyro!
No problem! I'm new to gassers also, but I'll try to help:
My choke lever has a wire attached, and protrudes to the opening of the cowl. It is very easy.
On my airplanes, the kill switch will be via an opto IBEF, which I can use to kill ignition via my transmitter, or automatically when signal is lost.
I pull the choke, flip the prop until it pops/sputters, and then push in the choke, restart, and fly.
Thanks!!!:)
I got everything figured out except where to make the input for smoke oil on the muffler.
Will this muffler even work? The stock OS one? Or do I need a can?
Thanks,
Alex
Joe's Dad
Have never wrapped the smoke tubing on any of our planes. Put the nipple as close to the inlet to the muffler, pointing into the muffler.
IE
Position the muffler on the engine.
Put the nipple as close to the exhaust port as possible. but make sure it is squirting into the muffler.
You dont want the smoke oil going into the cylinder.
Lots of different opinions on smoking. We do what works. Just check out any of our videos.
Use good high temp smoke tubing inside the cowling, a check valve. Filter not important at all. Use stainless wire to tie the tubing onto
the nipple.
