GSNadmin
From FMS:
The giant FMS Beaver 2000mm combines stunning beauty and realism with upgrades, updated technology, and new features. The largest propeller aircraft offered in the FMS line is a giant scale gem that offers incredible value.
Not only does it look fantastic, the Beaver performs superbly. The thrust force can reach more than 5000g and the flying weight is only 3800g. With a classic, elegant black and yellow trim scheme, the Beaver combines breath-taking visuals with its impressive performance specs. Capable of leisurely low and mid-speed flight, this model still maintains surprising aerobatic qualities.
Easier than ever
With the latest multi-connect technology, FMS has streamlined the wiring system, making it easier to install and eliminating wiring problems. Easier plane transport is facilitated by the new connectors that allow pilots to remove and replace wings with just one step. All channels on each wing are brought together in one port. The customers can install the main wing set simply by inserting the port and then securing with four screws.
Night Flyer
To make flying the Beaver more fun at night, there are five LED lights. Light up the night with LEDs located in front of the main wing set and at the rear of the fuselage.
Scale detail
The aileron and flap are to scale. The latest EPO52 foam material as well as the hollow main wing greatly alleviates the airplane weight.
Upgradable
Electric retracts and floats are available to add to the package. These retracts will make your model ready to tow banners and gliders. With optional floats, the Beaver’s high-powered motor is ready to be put to the test of a water take off.
History
The DHC-2 Beaver is a general purpose bush plane developed by de Havilland Canada. Though originally used for cargo/passenger hauling and crop dusting, it was also adopted by the United States Armed Forces as a utility aircraft and search and rescue unit. The single-engine, high-wing, propeller-driven STOL aircraft appeared in both the Korean and Vietnam Wars and was popular among front line men. When production finally ceased in 1967, only 1,657 DHC-2 Beavers had been built.
Features:
- Multi-connector for easy assembly
- Lighter EPO 52 foam
- Metal landing gear designed for hard landings
- Scaled LED night lights
- Large tires for any surface
- Servo box design for easy assembly & disassembly
- Scaled flaps
- Newly developed lightweight hollow main wing
- Oversized battery hatch for 6s battery and 15 minutes of flying time
- Optional upgrades
Needed To Complete:
- 5+ Channel Radio System
- LiPo Battery and Charger
What’s in the box?
- (1) Beaver 2000mm PNP
- (1) User Manual
Specs:
Aileron: Yes
Approximate Assembly Time: Less than 1 Hour
Approximate Flight Time: 8 minutes
Battery: Li-Po 22.2V 4000mAh 35C
CG (Center of Gravity): 2.76 – 3.00 in (70 – 75mm) From Leading Edge
Completion Level: Plug-N-Play
Elevator: Yes
Flaps: Yes
Flying Weight: Approximately 8.4 lbs (3800g)
Length: 51.3 in (1304mm)
Material: Durable EPO
Minimum Required Radio: 6 Channel
Motor Size: Brushless 4258-KV550
Propeller Size: 15×9 2-blade
Retracts: No
Rudder: Yes
Servos: 17g Metal Digital Servos – (6)
Speed Control: 70A
Wingspan: 78.7 in (2000mm)
FMM090P – $329.99
Visit FMSModel.com
See more posts about FMS
Continue reading...
