Ok here is my Life battery consumption. Today I flew 15 mins. On last Sunday I started the plane and let it run for 2 mins or so, but I am not counting that.
In Summary I run two Glaicer 2100mah 2s Life packs to a PowerSafe RX and use a Tech Aero IBE and a DA-50 Ignition. .
The first battery took 23:05 mins to charge to a voltage of 7.20v and put back 500MAH. The second pack took 22:04 mins to charge to a voltage of 7.20v and put back 502MAH
So am I correct to assume of a total capacity of 4100mah, I used 1002mah in 15 mins that is using 66.8mah per min 66.8 x 40 mins is 2672mah. So If I flew 4 10 min flights there should be 1428 mah left between the two packs, but when I divide that number to see whats left in each pack, its only 714mah (roughly below 1/3). How far down can I consume the packs before they are in danger?
Am I doing this correctly? Heck, I guess I could just do three 10 mins flights and charge, it only takes 23 mins at 1C.
my initial guesstimate is I would be able to do 4- 10 min flights without risk of depleting the RX Life packs too far.
