3dRCparts.com
In the tail.
Peel the covering off the bottom and wick CA into all the glue joint. add cross bracing. Reinforce where the cross pieces connect to the formers, and where any stringers and sheeting connect to formerss with stock, ca epoxy and micro-balloons....
also, where the last former connect to the tail with a flat plate, really get CA into that piece.
lucky me, the entire bottom panel is off due to the covering coming unglued via smoke oil, I can do a mod build, but I can't see where it would need cross bracing, this looks to be extremely well engineered, kinda a copy of a carden build with more carbon fiber, I know the glue the chinese factories use leaves a lot to be desired and will go over all the joints. Do you have any pictures of where the additional bracing should go?
