les2097
This engine has four flights on it... then the plane was not flown again by my friend...
I bought the plane and now want to sell the engine... It comes with stand offs, ignition, and muffler. The muffler is not the original, but is from a DLE 55 engine that had the down tube come off... the same thing happened to the original muffler on this DL 50 so I used the muffler with the newly welded down tube from the 55 as we couldn't find the tube from the 50...
Engine runs GREAT... starts easily and has about 30ounces of fuel through it... Pennzoil at 40:1 ... looks new...!!
Stock Specifications:
Engine Type: Gas
Displacement: 3.100 cu. in.
Cylinders: 1
General Specs:
- 1 cylinder
- Displacement: 3.100 cubic inches
- Bore: 1.693 (in.)
- Stroke In: 1.378 (in.)
- Shaft: Single + 4 bolt
- Low RPM: 1350
- High RPM: 9000
- 5.200 bhp @ 7500 RPM
- Weight (no muffler): 47.62 oz.
Engine Type: Gas
Cylinders: 1
General Specs:
- 1 cylinder
- Bore: 1.693 (in.)
- Low RPM: 1350
- High RPM: 9000
