Brand new Airtronics SD10G 10 ch RX Low price!!!!
mups53
Full warantee included
Price dropped!!!!
Brand new 2 weeks old never opened.
$305 plus shipping $15 UPS ground cont us.
Paypal or Money oredr check.
Let me know thanks, Mike
Airtronics SD-10G Transmitter
10-Channel 2.4GHz FHSS-3 Aircraft Radio
*This version of the SD-10G Includes the Airtronics 92104 10-Channel 2.4GHz FHSS-3 Receiver*
The SD-10G is a 2.4GHz 10-channel high-performance digital proportional computer radio control system designed to give both sport and competition pilots a radio that is easy to use, powerful, flexible and yet very affordable. Using Airtronics' reliable 2.4GHz FHSS-3 technology with Safety Link, the SD-10G is ideally suited for competition fixed wing aircraft, sailplanes and helicopters.
The SD-10G features 10 channels, a 10-bit computer and is as much as 10 times faster as some older competition systems. Featuring bullet-proof FHSS-3 (Frequency Hopping Technology), Airtronics 2.4GHz has already gained a reputation as a no-hassle, reliable spread spectrum solution, 'fairly' earning Airtronics/Sanwa Engineers, the nick-name "The 2.4GHz Specialists".
The SD-10G was developed by Sanwa's best and brightest computer programmers in concert with the most experienced pilots from Sanwa Japan and Airtronics USA. From F3J World Champions to 3D Helicopter Experts, from AMA Hall-of-Famers to Pattern Nats Champs, the team who planned and put together the SD-10G are some of the most dedicated and experienced modelers in the world today. We've worked with pilots for more than an year to ensure every detail, every nuance was developed for the modeler, both sport and competitor.
You'll find the SD-10G is incredibly user-friendly and easy to setup, yet allows for flexibility not found even in radios at twice the price. Sport pilots will find their model easy to setup. Advanced pilots will love the customizable features that truly make this radio unique. As modelers, we know performance is not free, but the team at Airtronics worked hard to ensure the SD-10G offers both industry leading performance and value.
And the SD-10G is fast. In our side-by-side tests, we found no other 9- or 10-channel radios to be faster. The Sanwa high-speed computer chip works together with its unique high-performance 2.4GHz RF chip to ensure your inputs are translated at industry-leading speed to the servos. Your servos will feel faster, the radio will respond quicker and you'll wonder how you ever did without.
We could go on and on, but let's make it quick and easy. Whether you fly for sport or compete at the highest levels in categories such as F3J Sailplanes, Pattern, IMAC, Scale, Indoor Foam, Micro Helicopters, or 3D (and that's heli or plank) you'll get the Advantage. You will see there has never been a radio like this in our hobby, a radio this advanced, this reliable and this fast. And remarkably, you will find the SD-10G truly affordable.
*The SD-10G features a Trainer System that is compatible with all Airtronics SD series transmitters.
Latency Speed Test
The SD-10G is absolutely the FASTEST radio in its class. The faster the latency, the quicker your model reacts to your control inputs and the more connected you feel to your model. These latency findings were taken using carefully contructed and consistent methods to ensure they are as accurate as possible*.
Airtronics SD-10G with 92104 10-Channel FHSS-3 Receiver:
• MIN: 7.36ms / MAX: 16.3ms / AVG: 11.83ms
Futaba 10C (Futaba is a Trademark of Futaba Corporation and Distributed by Great Planes):
• MIN: 9ms / MAX: 29ms / AVG: 19ms
JR 12X (JR is a Trademark of JR Radios Japan and Distributed by Horizon Hobby):
• MIN: 21.5ms / MAX: 43.5ms / AVG: 32.5ms
*As of May 2009
General System Features:
• 10-Channel Digital Proportional Computer Radio with Advanced Programming
• Designed for Competition Fixed Wing, Sailplane and Helicopters
• 2.4GHz FHSS-3 / FHSS-1 Technology (Selectable)
• 10-Channel Programmable Fail Safe (FHSS-3 Only / 4 -Channel Fail Safe with FHSS-1 Receivers)
• Compatible with Airtronics 2.4GHz FHSS-3 and FHSS-1 Aircraft Receivers
• 6 Cell 1500mAH Rechargeable Ni-MH Transmitter Battery
• Direct Model Select
• Programmable Custom Menu
• Easy-to-Read LCD Display with LCD-Only Display Switch
• Simple Wing and Model Templates
• Servo Reversing, Centering, End Point Adjustments, and Limits
• Six Digital Trim Switches
• 3-Axis Triple Rates and Bi-Directional Exponential
• 3-Position Programmable Switches
• 2 Programmable Side Levers and Programmable Dial Knob
• Optional 'Stiff' Control Springs to Fine-Tune Control Stick Feel
• Optional Throttle Stick Stops to Limit Control Stick Travel
• User Naming, Model Naming and Model Select
• FHSS-1, FHSS-3, and PPM-8 Modulation Selection
• Low-Power Range Check Mode
• Adjustable Receiver Battery Fail Safe Voltage
• Trainer System
• User-Selectable Modes
• Programmable Channel Assignments
• Stick Switch Functions
• Stop Watch, Rhythm, System, and Integral Timers
• 20 Model Memory with Data Copy, Reset, and Transfer
• Add-On Memory Expansion Card and PC Connectivity
Common Programming Features:
• Servo Monitor
• Stick Monitor
• Aileron/Elevator/Rudder Triple Rates
• Aileron/Elevator/Rudder Bi-Directional Exponential
• Channel Delay
• Digital Trims
• Trim Step Resolution
• Trim Authority
• Variable Resistance Lever Assign
• 5 Flight Modes
• Flight Mode Copy, Delay, and Naming
Aircraft-Specific Programming Features:
• 9-Point Throttle Curve
• Throttle Hold
• Throttle Cut
• Idle Down
• Aileron Differential
• Aileron/Elevator/Rudder Offset
• Cross-Trim
• 2 Programmable Snap Rolls
• 10 Programmable Mixes
• 5 Compensation Mixes with 9-Point Curves
Sailplane-Specific Programming Features:
• Six Servo Wing Capability
• Landing Override Mode
• Landing Differential
• Landing Flap Freeze Point
• Landing Crow
• Camber and Camber Point
• Cross-Trim
• 11 Programmable Mixes
Helicopter-Specific Programming Features:
• Advanced Swashplate Control
• Throttle Cut
• 7-Point Hovering Throttle
• 7-Point Hovering Pitch
• 3 Gyro Gains
• 3 Governors
• 3 Programmable Mixes Plus Revo Mixing
Transmitter Specifications:
• Output Power: 100mW
• Operating Voltage: 6.7 v ~ 10.2v
• Current Drain: 240mA
• Temperature Range: 32ºF ~ 122ºF (0ºC ~ 50ºC)
• Pulse Width: 0.9msec ~ 2.1msec
• Weight with Battery: 32.8oz (930gr)
• Frequency/Modulation Type: 2.4GHz/FHSS-3 and FHSS-1 Selectable
• Model Memory: 20 (40 Using Memory Expansion Card)
• Memory Expansion Card: Proprietary, 20 Models (Available Separately)
What's In The Box:
• SD-10G 10-Channel 2.4GHz FHSS-3 Transmitter
• 92104 10-Channel 2.4GHz FHSS-3 Receiver
• 6 Cell 1500mAh Ni-MH Battery for Transmitter
• AC Dual Output Charger
• On/Off Switch
• Servo Extension
• User's Guide
Capt.Roll
Great TX........it's what I've been flying with for the last 18 months.
If no takers here, RCGroups has a very active thread on the SD-10G. If you haven't done so already it may be worth a post there as well.
SnowDog
If I didn't already have one, I'd consider buying this one! Great deal with a RX. I love my SD-10G; super low latency; rock solid dependability; easy programming; chock full of features. This is a good deal.
