ryan_m
Can anyone walk me though how to setup the dual elevator servos/mixing for this plane using a JR radio (9503)? Thanks
What JR radio specifically?
That's what I fly.
Easy to do.
I don't have my radio in front of me, but you need to go into the model selection menu area, under the sub menu wing type.
In there is the dual mate area. Under Elev it currently says IHN for inhibit, you need to change that to an open channel on your RX. Usually channel 5 (gear) works well. You may have to do to the Device Sel, and under the Gear part change that to Inh so that the radio frees up that channel.
That's basically all you have to do. No mixes. The only other thing you might need is to reverse the channel you used in the normal servo reverse menu if it moves the wrong way. And you can set the travel endpoints also of each channel separately to get them to move the same amount.
The dual rates and expo part will adjust both though.
edit: Looks like atomicflyer beat me to it!
