-Rick-
Thanks guys!
From all I have read and learned about this thing, the things I need to fix are...
Covering, china coat, rip it off!
Motor box, its weak, beef it up. I plan on rebuilding the motor box anyways as its had a few different motors mounted. It is a mess.
Rudder post, easy to come loose, when I got the plane it was loose already. Easy to fix and support.
Wings breaking, tube not tight in foam, not glued in properly. Also wings not supported past the wing tube, known to break 2/3 of way out in a snap roll. Need to put in some kind of a spar(s) past the tube.
Engine cooling, when I get to that point I'll be talking to you guys!
Anything I'm missing!?!?
