3D 30cc hazzbro extra
daman691003
Front dried. Tail glued and clamped
Should I keep doing build thread.
daman691003
Ohh for covering u bought white black and red. I will need a lot of help there. I have done tons of repairs. But never full planea
Of coarse you should keep doing the build thread. There is nothing difficult about covering it just takes practice and figuring out what method works best for you to get good at it.
Alky6
Looking good so far! I haven't built this one, but I would assume that if you can't find the piece in your kit, and there is stock available in the correct size, you'll have to cut some. I would suggest that you go through the plans/instructions to ensure that "available" stock is not required somewhere else. Making good progress though!
kwj48
Do I have to cut a piece for this
Yes most straight pieces you will cut yourself. Before gluing formers in I would lay everything out in order. Frame then glue. Also cover entire plan sheet with wax paper or clear plastic wrap. Some like parchment paper but I find it hard to see through. Use T pins to pin everything down.
