By the way @Hinckley Bill, when you say the original owner are you speaking of my airframe? Because it had no mounting holes of any kind in or on it, i.e. never been assembled....
			Robert,Those look like some really long stand-offs.. Was that mount modified or did it come shorter for the quad?
That's a beautiful machine.Well the AW made it to the field and even made a half a circle around the field. It went together as expected with the lower wing wiring being the only PITA. Fired it up at the start station, ran it up as far as I could hold it as there is some serious pull coming from this 3W with that 32x10. So I taxied out and started down the runway, just as it became airborne I noticed it had started surging. I pulled the throttle back some in hopes it would stay running long enough to make the turn back and it did and it landed as nicely as one could ask. After returning home and going through it turns out the sealant some how went into the pulse hole of the gasket and was plugging it up mostly. So I pulled the entire assembly apart and cleaned every spec of the sealant off and reassembled it, run's like a top again.
There is a video but it is not worth trying to upload and post, maybe the next time. But I did get one pic on with phone.
I'll go and get one.Robert,
Based on how the firewall and everything is locked together I believe that it was made specifically for the quad.....stand-offs are roughly 2 1/4"....plus ~1/2" for each wood mount (front and back).
Not thrilled with the setup but it works.
Concern I have now is for the overall width of the motor when the spark plug caps are put on....it appears that some cowl 'mods' will be required.
Any chance you could shoot a photo or two of your engine compartment with the top half of of the cowl removed, as I'd like to see the fit of yours with everything mounted?
Bill
Thanks you.That's a beautiful machine.
