Wanted to do a comparison of the 70cc class motors now that the specs are mostly out on the GP-76.
The GP76 is only 0.213"/5.41mm Wider cap-cap, 0.19"/4.826mm Longer Mount-Hub, and 0.088lbs/40g Heavier (without muffs or ign) than the DA70. so less than 1/4" dimensionally and under 1/10lb heavier. Not bad GP, not bad at all!
I'll update this as more info becomes available.
All motors listed below have the same firewall mounting of 66mm H x 78mm L. All come with Genuine Walbros, and NGK CM6 plugs. Weight shown below is without muffs/ign.
Engine: CAP-CAP dimension: Weight:            Price: Mnt-Hub:  Comes with the following:
GP 76     St Plugs  10.826"    1650g/3.637lb  $660    5.73"      Muffs, V?Ign, ?Yr Warranty
DA 70     St Plugs  10.613"    1610g/3.549lb  $749    5.54"
NO Muffs, 6.6V Ign, 3Yr Warranty
RCGF 70 Ang Plugs  9.37"     1508g/3.325lb  $499    5.65"      Muffs, HV Ign, 2Yr Warranty
EME 70   Ang Plugs  9.84"     1800g/3.968lb  $519    6.02"      Muffs, Hv Ign, 1.5yr Warranty
GP 76:
https://www.gpengine.world/archive/product/item/GP76 Three-View Drawing.pdf
DA 70:
https://cdn.shopify.com/s/files/1/08...73435843125876
RCGF 70:
https://www.rcgfusa.com/product/rcgf-70cc-t/
EME 70:
http://www.emehobby.com/UploadFiles/...0dimension.pdf
Mile High RC shows plug dimension 250mm with caps.
I hope this was educational and rewarding as it was for me!
