This is hard to believe but I checked the numbers a couple of times. The plane cam in at 4 lbs 15.5 oz and all the hardware and mean everything came in at 6 lbs 3.2 oz  so that gets me to 12 lbs and a couple oz’s. Do not think that is to bad for a plane that has wingspan of 85 inches and a wing area of just under 1400 square inches. Note this weight does not include covering which still needs to be done. Hopefully it comes in below the 13 lbs but most likely it will just go over, time will tell. And by the way @BalsaDust can you tell me the weight of your 50cc profile.
Now all I need to do is buy a DA50 for the plane.
