Xpress
		Yep it flies again!!
It flies even better than before too, with the new motor box and batteries pushed all the way against the first former the CG was dead nuts, flies perfectly level upright and needs a touch of down for inverted- perfect. Only managed 2 flights today on the set needle settings as instructed, will open up a small access hole in the cowl so I can get a screwdriver to the needles for adjustment
