With the disappointing performance after swapping a GP61 into my Pilot Edge I decided the canister might be clogged so I went through the process of cleaning it this week. After reading a post by
@Robotech I decided to use Berryman Chem-Dip carb and parts cleaner. I capped the Stinger end and filled it with the cleaner. I let it sit a few days and emptied it and rinsed it with water, then blew it out with compressed air. I got a lot of chunks of carbon out, but realized that when I filled it I should have tilted it back and forth to make sure all the blocked areas actually filled.
When draining the water out I could tell it was still somewhat clogged because I couldn't get all the water out of it without shaking while blowing 150psi air through it. And even then it took a long time.
Thursday night I refilled it with the Berryman, this time tilting it back and forth to make sure all the chambers were full. Then Friday night I drained and rinsed it again. I didn't get a lot of chunks this time, but the cleaner was black as tar. When rinsing it this time I could easily get all the water out of it by blowing air in the inlet. It seems to me to be pretty open inside now.
Last night I installed it on the airplane and today I'll test run it and see if it helped.
Inlet before and after. I think a longer soak would really get make it spotless.
View attachment 89133 View attachment 89134
Outlet before and after.
View attachment 89135 View attachment 89136
