Aerobeez 70″ Slick PRO Step By Step Build Guide
Bloosee
Wonderful motors.
[MENTION=3728]Bushwacker[/MENTION] my only problem with them is the prop shaft is too short to run a XOAR prop with spinner. I found a spinner with a thin backing plate that allowed me to get the nut 90% of the way on and it has held up for of a year or 3D flying. I've been in contact with Ken about this. We've traded several emails, finally last month he said his Chinese factory will be making him a batch of 100 long shafts, he should get them within a month. If you have a problem just let Ken know about it, like I said he is a aware of it but its good to hear from other customers as well.
Bushwacker
3DRCF Moderator
Good to know. Although Im running the DM-4320 with a Xoar 17x10/18x8 and a EF Elite spinner on my 3DHS 65" Vyper. All fits really nice. Hopefully I won't have this trouble with this larger motor.
Bushwacker
3DRCF Moderator
Quick question. Is that a 76mm carbon fiber spinner and where do I get one?
Edit: Nevermind I think I found it. HERE RIGHT?
Edit Again: I think maybe that is not the right place. Bolt pattern is wrong and I have no mounting hole in the shaft.
Unless this is not a 3" spinner. Is it maybe a 2.75"
Bloosee
Coolness...So is it a 3"?
[MENTION=3728]Bushwacker[/MENTION], yes, the spinners from Esprit come in all sizes. I tried an Extreme Flight spinner, but they have a thick backing plate that would not allow me enough room for the prop nut. If Ken has the new long shafts available, get the EF, they are top quality.
Bushwacker
3DRCF Moderator
Well [MENTION=2902]Bloosee[/MENTION] looks like I got lucky bro. Dry fitted an old Xoar 18x8 prop with an Elite spinner and all is good to go. Got some aircraft aluminum 5/8 round stock so I'll be machining that down to make my motor stands and I'll be done.
Bushwacker
3DRCF Moderator
Oh ya man. This thing is almost the same size as the 850MX Dominator in my 700 sized Heli.
