3dhs 92" edge 540 !!!
SnowDog
inspires me to at least consider the idea of flying outside in the winter when the hight temp is 5 and the low is -20 :|
wedoitall
Member
Great thing about low temps is no wind usually. I'm playing hooky at work tomorrow to go flying. Suppose to be the first day with no rain and above freezing temps. 33 degrees as a high.
Off topic but can someone post what the setup is for the removabole rudder? I know what hinges are need but I need to know how the wire is installed and retained once installed. I want to do this same method for a removable rudder on another airframe but need a little insite on how its done. I have a few ideas but seeing how it's implemented on a box stock airframe would help. I really appreciate it! Thanks!
vegasking
I use these for a removable rudder setup. Secraft Easy Couplers @ http://store.aztechaeromodels.com/store/index.php?route=product/product&path=61_81&product_id=93
Bivens
Yowzilla...choke rod looks cool. In that 1st pic I did notice something worth asking... Is seems that the spark plug wire passed through a hole on the cowl....this can rub/cut into the wire very quick if not protected...what have you done to keep it from rubbing?
Diggity
Yeah I have a few sets of those to use. Can someone post a pic of their rudder installation and how the rudder pin is kept in place? Would really appreciate it. Thanks!
Here ya' go!
Here ya' go!
Awesome! That is how I was expecting to see it. Only question is on the top of the rudder is the wire bent at a 90 degree then recessed in the top of the rudder or bent 90 then another 90 with the point of the wire going down into the top of the rudder? One other question...are you the one running the new DLE-61 in your 92" Edge? If so how do you like the engine? I'm kind of between a DA60 and DLE61 for my next 30% build. Thanks!
