The right wing extension is complete. I will fill the extension with low expansion foam because that's right where the plane will be picked up. While the fuselage is stilled jigged on the side two 1/2" holes were drilled for the locating pins. These will be fitted with 1/2" hardwood dowels. Made a template so that left side holes will line up and I can drill straight through into the wing. After looking at the wing tips decided to go the foam route as they are rather large and would take a 3" x4" block of balsa. At this point they will be the lost foam method. Ready to flip the fuselage over and start on the left wing.
