Discussion The I’m Going/Went Flying Thread
Tried to go flying today changed the power packs and went to the field checked the rx pack and it had zero volts I mean absolutely zero. Never seen that before, so went home to figure out what is going on.
Well that's no good. in 2020 I've lost a lot of LiPos... bunch of foamy LiPo's were getting hot... guessing they are building up IR. couple days ago I was charging up a 2S 450mAh and it was starting to puff and get hot.... yikes! Time to retire another.
Sounds to me like your lipo has a bad connection? check the voltage to the main connector, then investigate a bad wire connection. That's frustrating!
Took everything out of the plane checked the battery sure enough it was flat and mean flat.o5 volts in one cell and .06 volts in the second never seen that before. Yes in trash and installing a new LiPo .
What Chemistry/Brand was it? Graphene?
Well another good day at the field put a bunch of flights on the Timber really starting to get on to it. The new generator worked out well, now I can charge at the field all day long, all the power I need now.
Wild man
My older Brother and a few of my Student Pilots bought me this FMS Hawk In appreciation for all the test flying and Instruction I have done with them. I did the test flight with it this morning. The Hawk is a very stable and fast EDF. The recommended throws are a little high after take off I put all three Rates in low. Which were lower than what is in the manual. Every thing went great. I would recommend this EDF even for a first Jet for any intermediate Pilot I put four flights on it this morning after I got it trimmed.
