Servo Arms
What servo arms do you use?
  • Total voters
    41
Xpress
So everybody uses servo arms right? Right?? :confused??:
So what kind of servo arms do you use?
-Stock cheapie plastic
-Heavy duty plastic
-Aluminum
-Other (explain)
slowgto
Most of the time aluminum... except for the throttle, then I use one of those hybrid fiberglass-composite-plastic jobs. In my head it makes sense as it keeps the vibrations down on the throttle servo.... real world I have no clue.
How do the HK aluminum arms hold up?
Look just like the SWB's but fit the splines better. Tension screws are 2 mm though and not 4-40. Mine have been doing fine in my 104. The current ones should hold up well and now come in many different styles. Purple one is on my purple edge! lol
Capt.Roll
I agree with Dimes.........the HK arms have been holding up very good and I haven't had any reservations using them up to a 120cc size ARF.....only because that's the largest ARF's I've owned.
The pic on left is the style I've used the most. That style is anodized a color to help ID it for the servo output shaft; purple is Futaba (23T), there are silver and gold for other shafts with a different tooth count or diameter than Futaba.
