RCXL Optic Kill switch
Spats
Needs some input guys, I am thinking of trying an RCXL kill switch. I know nothing about them. Who has used them and does it just plug in between the receiver and the regulator/battery to the ignition? Safe product?
Thanks, Randy
BarracudaHockey
Spats;2363 wrote: Needs some input guys, I am thinking of trying an RCXL kill switch. I know nothing about them. Who has used them and does it just plug in between the receiver and the regulator/battery to the ignition? Safe product?
Thanks, Randy
Awesome. Use that or a Tech Aero IBEC on all my gassers. I have hundreds of flights with them and they work as advertised.
You want
Battery > mechanical switch > rx exl kill > Ignition
Then the rcxl plugs into an aux channel.
Good stuff and cheap insurance against mechanical issues such as servo or linkage failure on the throttle
Spats
BarracudaHockey;2375 wrote: Awesome. Use that or a Tech Aero IBEC on all my gassers. I have hundreds of flights with them and they work as advertised.
You want
Baracuda, Thanks. Just to get it straight I can just plug it between the existing Badger switch and RX?
ChickenBalls
"Cool Guy"
[MENTION=201]Spats[/MENTION] I have them in 2 50cc gassers, no issues at all. I did have the Tech aero ibec, and my A9 didn't play well with it. There are several others using the rxcel that I fly with, and no issues, can't beat them. They work, reliable, and only cost $13
BarracudaHockey
Spats;2384 wrote: Baracuda, Thanks. Just to get it straight I can just plug it between the existing Badger switch and RX?
No, they go between the ignition battery switch and the ignition, then a 3rd lead goes to the receiver.
If you're powering everything off one battery you're better off with a Techaero IMO
Note: I dont use Badger switches so I'm assuming they function like a normal switch.
Spats
BarracudaHockey;2386 wrote: No, they go between the ignition battery switch and the ignition, then a 3rd lead goes to the receiver.
Ok, I get it now. Makes sense.
Thanks
I am using 3 of them. no issues on about 140 flights. The way I see it if rcexl is good enough to make the ignition they should be qualified to make an ignition cutoff. I have not modified any as shown on the instructions to work with no battery yet though.
N726AC
Lorne @pro-rc.ca;2571 wrote: I am using 3 of them. no issues on about 140 flights. The way I see it if rcexl is good enough to make the ignition they should be qualified to make an ignition cutoff. I have not modified any as shown on the instructions to work with no battery yet though.
Hi Lorne! ( I'm just post whoring again) ;)
Spats
Good to know. Thanks.
N726AC;2578 wrote: Hi Lorne! ( I'm just post whoring again) ;)
Yes we all need to get our count up to get out of the glow group.:D
