camss69
Back in the day using Tygon for a clunk line with no brass tube I had the clunk get stuck in the front of the tank after a blender.  It caused a dead stick and an unplanned landing out in the field but luckily just some bent gear and no other damage.  I've used a brass tube in the clunk line ever since.  I've never run straight Viton as a clunk line though..
I was wondering about using a soldering iron to make the holes but then a friend recommended using a cone shaped sanding/grinding attachment on my Dremel to make the holes and that worked great. I think it's actually some kind of grinding stone looked like a mini uni-bit but it works great. It came with the Dremel and I've never really had a use for it until now.
