i have a very easy solution for my problem.  right now, there is a 1/4" thick plywood mount between the DA 150 and the motor firewall.  then, behind the firewall, there is a 1/4" thick aluminum back support.  the aluminum weighs 2 ounces and the plywood mount weighs 1.3 ounce.  what i can do is obtain a 4" by 4" steel plate that is 1/4" thick, use this in the front between the motor and the firewall.  this will also help dissipate heat???, (maybe), then, i can use a back support of 1/8" steel that is 4 by 4", this will add about 1 pound and 10 ounces.  i have calculated i need 1 pound and 8 ounces in the nose to make her even.  by doing this, it will not move the motor forward, i will still have a nice spinner gap, i will not have to change the baffles, and i will not have to move the rudder servos.  it is, however, adding dead weight. but, i consider the fact that this airplane before had a 3w 157 in it, that weighs 1.5 pounds more than the da 150L.  so that airplane flew great with that setup and that weight, and it won contests, as far as i am aware.  so i am sure it was well balanced like that.
