TonyHallo
Following are a few photos of jigs I used on the Super Cub and the Champ.
For the landing gear the legs are mounted on the attachment points and can be flipped over by the axle.
For the fuselage the front plant is scaled down from the full scale version. You rotate the fuselage from the plate, a short axle is mounted the the landing gear plate with standoffs
TonyHallo
For the wings, they are mounted at the root and the lift strut points, the can rotated 90 degrees without touching. the lift struts are 1/4" steel bars drilled for 4-40 at the lift strut attachment point and threaded at the center box for adjustment. The ailerons are jointed with 1/4" wood dowel the the hinge points.
View attachment 125054View attachment 125055View attachment 125056
Tony, was wondering if the tail would need support in a rotisserie setup. I like your precision tail support....
Working on a firewall plate design. I'll cut something tomorrow.
TonyHallo
If the tail is not supported you need a cantilever setup. The 3/4" pipe has a flange bolted to the firewall. The pipe slips into a larger tube clamped in the vice on a mobile work bench. The plane is rotated and held in position with a pair of vice grips.
