Manoeuvre help
I've seen this manoeuvre a few times and would appreciate if someone could tell me the control inputs. Since I don't know what it's called, I'll try to describe it. The aircraft is put in an inverted orientation, throttle is added. The plane then does a fast inverted flat spin in one place without losing altitude. I understand that left or right rudder is added depending on whether you want to rotate CW or CCW. It's the aileron input which I think catches me out.
I am thinking he is looking at a Pot Top
No not that. What I'm referring to is like how you do donuts in a car. The car is pivoting in a small circle. Similarly the aircraft is spinning in a fast tight inverted flat spin in a small circle. At the same time not losing altitude like you would in a normal flat spin.
Phil.Griffin
There are lots of examples of this around, I just can't remember where at the moment. Look at the video from 3:40-3:48. I think this is basically the maneuver you're speaking of? Sometimes it's done faster, or flatter, but it's my understanding that this is called a funnel hover. Not being an expert on any of this I may be wrong however.
The "VORTEX" ???
