Legacy Aviation - 84" Turbo Bushmaster - Yellow / Black
3dmike
The Legacy Aviation Turbo Bushmaster raises the bar for Sport/Scale fun and excitement! Based on the venerable Turbo Beaver, one of the all time great bush planes, this Cody Wojcik design is quite simply one of the best flying RC planes we've encountered. We passed the sticks around at numerous flying events in 2015 and the response was overwhelming! "I gotta get one of these!" is what we typically heard.
Big and light, the Bushmaster is as gentle and forgiving as any trainer we've ever flown, making for a very enjoyable and relaxing flying experience. Flip the rate switches and the model transforms into an extremely capable aerobat! Experiment with the various flap mixes that are possible and you open up a whole new envelope of high lift/high drag maneuvers. Although the Beaver spans 84" our prototypes have typically finished out below 8 pounds! You can imagine how "floaty" a model of this size is at that weight!
The Beaver features a 2 piece wing mounted on a carbon wing tube that is easily removed for transport. It is designed around our Torque 4016T/500 outrunner and Airboss 80 Amp controller and uses a 16x7 prop and 6S 3300-5000 mah batteries for best performance. It uses 6 metal gear mini servos (our prototype models were flown with Hitec HS-5245 and 7245 servos). A modern computer radio with at least 7 channels is required to take advantage of all of the functions this model is capable of.
A float kit that is extremely easy to assemble and install will be available soon which will add yet another dimension of fun and excitement to this amazing model!
MEDIA:
VIDEO:
[video=youtube;mxAqeDd4Gj8]https://www.youtube.com/watch?v=mxAqeDd4Gj8[/video]
URL: http://northwestrc.com/Legacy-Aviation--84-Turbo-Bushmaster--Yellow-Black_p_242.html
Product Information
Specifications
Wingspan: 84 inches
Length: 64 inches
Wing Area: 800 sq. in.
Weight: 7.5 - 8.5 lbs.
Electric Power System
Electric Motor: Torque 4016T/500 MKII with 6S 3300-5000mAh, 16x7 prop
Electronic Speed Control: Airboss 80
Note: Due to the location of the ESC in relation to the battery, a battery lead extension of 8-10" is required.
Note: A separate Rx battery or independent Battery Eliminating Circuit (BEC) must be used. The BEC on board the Airboss 80 is not sufficient to power six servos. We recommend the Castle Creations BEC (10 amp).
Servos
Qty. 6 Hitec HS-225MG (Good)
Qty. 6 Hitec HS-5245MG (Better)
Qty. 6 Hitec HS-7245MH (Best)
Qty. 6 Savox SV-1250MG (NEW) requires slightly enlarging servo locations
Servo Extensions
Ailerons qty. 2 - 18"
Elevator qty. 1 - 24"
Flap qty. 2 - 6"
ESC qty. 1 - 12"
Radio Requirements
Modern 7 channel computer radio
Bipenut53
So here is [MENTION=335]SupaTim[/MENTION] flying his Turbo Bushmaster!!! So cool!!!!
[video=youtube;sU8MJjUrRa4]https://www.youtube.com/watch?v=sU8MJjUrRa4[/video]
Xpress
I totally fell in love with this airplane at the Arizona Electric Festival this past weekend. It's so solid all around, makes for a GREAT high wing sport trainer, go from mild to wild in a heartbeat. Gotta give my thanks and gratitude to Supa for letting me burn through some electrons in his arsenal of electrics- from the new 60" Slick 580, to the Duster, to the Bushmaster, to his totally rad 92" electric 3DHS Edge.
Also I got to fly the Turbo Bushmaster into the Arizona sunset which was really frigging COOL!!! :D:cool:
Bipenut53
I am loving mine more and more!! Great airplane, loves pop tops and blenders lol
