Legacy Aviation - 65" Turbo Duster IT'S HERE!!!!
3dmike
IT'S FINALLY HERE AND NORTHWESTRC.COM HAS THEM IN STOCK!
lgcy-duster-r-2.jpg lgcy-duster-r-3.jpg lgcy-duster-r-5.jpg​
63" Turbo Duster
Inspired by the latest turbine crop dusters, the Turbo Duster is a great sport scale and aerobatic model from Legacy Aviation. It is constructed of premium balsa and ply and covered in genuine Oracover/Ultracote. The Turbo Duster Uses 6 medium metal-gear servos, such as the Hitec Hs-5245MG, and includes big double-hinged flaps for all sorts of mixing possibilities.
Paired with our Torque 4016-500 motor and Airboss80 ESC, the Duster has unlimited vertical power on 6S 3000-4000mah lipo batteries and 16x7 prop. NOTE: The Duster is designed for low-pitch props, 7" pitch and lower.
The Duster makes a great rugged and friendly sport model, it can fly a variety of conventional and 3D aerobatic maneuvers, and it loves making low passes like its full-scale crop duster relatives. A carbon wing tube, carbon landing gear, lightweight and strong airframe, easy handling, quick assembly, easy-access hatch, and a complete high-quality hardware set add up to a fun and rewarding model aircraft you will be proud to own.
If you want a truly flexible airplane, order the optional composite color-matched float set (Coming Soon!). Custom-designed for the Duster, our floats are light, strong, include a complete double water-rudder setup, and you change the model back-and-forth from land to water in under 5 minutes with just one hex driver. NOTE: The float set requires one additional mini servo to operate the water rudder.
[video=vimeo;137292433]https://vimeo.com/137292433[/video]
url: http://northwestrc.com/Legacy-Aviation--65-Turbo-Duster--Red-White-Scheme_p_199.html
Product Information
Specifications
Wingspan: 65"
Length: 55"
Wing Area: 747 Sq. Inches
Weight: 5 lbs. without battery
Motor
Torque 4016T/500 MKII
ESC
AirBoss 80
Prop
16 x 6
Battery
3000-4000 mAh
Spinner
52mm (2 inch)
Servos
6 x Hitec HS-225MG (Good)
6 x Hitec HS-5245MG (Better)
6 x Hitec HS-7245MH (Best)
Servo Extensions
Elevator, Rudder 2 x 24"
Ailerons 2 x 12"
ESC 1 x 12"
Flaps 2 x 6"
Bipenut53
I have to agree with you [MENTION=2643]3DMIKE[/MENTION], when I was at his warehouse this airplane was on one of the stands. It is a really good looking airplane. I have always had a soft spot for crop dusters, this one looks its part..... Until you kick the high rates on and cut loose... Here is [MENTION=335]SupaTim[/MENTION] flying this airplane....
[video=youtube;lIZqjCdNxJk]https://www.youtube.com/watch?v=lIZqjCdNxJk[/video]
Get your Turbo Duster here at NorthWestRC.com
Bushwacker
3DRCF Moderator
You know what would really be supper cool is if somehow a fella was to equip this thing so colored
smoke or some other kind of medium was to come out of the wings to simulate actual crop dusting. :)
Bipenut53
Well..... Mrrcsound makes a smoke system for electrics that the smoke is pumped through tubes, Ive seen people use that system to put smoke out the wing tips... Maybe you could figure out a way where there is small nozzles the length of the hoses.......
