Xpress
		Thanks for the clarification. I was almost sure that I'd seen them in a HV application but figured I must be wrong. @ChickenBalls do you know the HV torque/speed specs in those?
The HS-7955TG servo was introduced before HV specific servos came about. We ran a lot of extensive tests on it and found that it can handle direct 2S Lipo just fine, but it is the only servo in our pre-HV lineup that will handle HV no problem. I run 6, 7955's in my 35% Yak on HV without issue, they are a little bit noisy at center and get the minimal load jitters we have explained before but once the engine is up and running and airflow is moved across the surfaces they will be rock solid.
We don't have official torque ratings on 7.4v for the 7955 but it will be similar to the 7954. Somewhere around 400oz at 7.4v. All I know is 2 of them is plenty for a 35% that has HUGE oversized ailerons (bigger than any 35% out there now).
Either 7955 or 7954 will be great.
