http://hitecrcd.com/products/servos/giant-servos/digital-giant-servos/hs-1000sgt/product
Holy power batman! Rated for 11.1V or 14.8V!!! :veryshocked:
The ultra heavy duty, giant scale HS-1000SGT delivers digital precision and high voltage punch to your most demanding projects. Designed with an all-aluminum, EMI-shielded case, solid steel gears and non-programmable digital circuitry, this powerhouse servo can tackle the most extreme 1/5th scale vehicle stunts and giant scale aerobatic maneuvers in addition to the industrial applications that inspired its original design. Capable of operating on 14.8 volts, the HS-1000SGT is the ultimate in power and durability.
Features
Non-Programmable Digital Circuitry
EMI-shielded Cases
Durable Steel Gears
14.8v 2-Cell LiPo Capability
Specifications
Motor Type: 5 Pole Carbon Brush
Bearing Type: Dual Ball Bearing
Speed (11.1V/14.8V): 0.26 / 0.19 seconds
Torque oz./in. (11.1V/14.8V): 1167 / 1528 oz-in
Torque kg./cm. (11.1V/14.8V): 84 / 110 kg-cm
Size in Inches: 2.52 x 1.30 x 2.87
Size in Millimeters: 64 x 33 x 73
Weight oz.: 12.80 oz
Weight g.: 363 g
Features
EMI-shielded Cases
Durable Steel Gears
Specifications
Weight g.: 363 g
