Rick dazzler
Mike!!!
Detail, details, details!:banana:
How much and when? Money in hands:flyer:
Mike!!!Detail, details, details!:banana:
Well here is a little something from Mike, "Ok guys... I'll answer any question I can but some insight into our thought process first:
The Aurora is an incredible platform but fell short in some areas... The 9X shores these areas up and allows for even further enhancements where the current radios memory was capped out.
1. Performance:
a. 4096 resolution (4 times better/ 2X better than Futaba and Spektrum)
b. Dual processors (one for programming, one for RF)
c. Re Engineered signal processing so the Optima RX performance is twice as fast (19ms frame vs. 41ms)
d. New Maxima RX's (Non Telemetry) have a 7ms frame which outputs all channels simultaneously for the absolute minimum latency. (FBL version in the works)
2. Case design:
a. Slimmer back with integrated stylus pen.
b. Vibration warning in rubber grip
c. Battery connector uses J plug (no plugging in backwards)
d. A & D switches are now 3-pos.
3. SLT: This is built in and selectable. With this protocol being open, any manufacturer could offer models compatible with it. EDIT:more info from Mike on this(SLT: Compatible with any TX-R model made by G.P. or any company that utilizes the protocol which we expect to expand significantly. Hitec will not offer a stand alone SLT RX but future BnF "Hitec" branded models (Many more planned) will utilize it thus keeping the cost down. )
4. Head tracking: The 9X will support this.
5. Binding/protocol select: Built into the programming... no pushing buttons (except of the RX.)
6. Programming enhancements:
a. 7- point curves on all mixes
b. Stick activated switches
c. Swash ring (Kinda late of this one)
d. There's more, but I'm not listing everything.
Essentially, our goal was to update an already awesome product and not to change the category it was in by adding things that would significantly add cost. Note that the current A9 will not be discontinued. I am very pleased with the updated version and while it might not be a big enough jump for some to change, it does address the shortcoming of the current radio and allows us to compete better with any high performance radio on the market today reguardless of cost. Yes, we know that some wanted more channels but at this time, that was not possible and what % actually can use more than nine anyway? The Aurora essentially changed the landscape of the radio market and the 9X will be a tremendous bang for the buck offering higher performance, resolution, speed, and versatility for the future to further change that landscape!
Mike"
