econpatric
[H=1]Manufacturer Description[/H]
Due to new technologies aircrafts and helicopters become more and more powerful. The A10 used to be our smallest high performance outrunner. The all-new design 12-pole A05 with only 7,5g is best for the new generation lightweight indoor and outdoor-models with approx. 150g.
The A05 motors are the smallest outrunners of our high quality motors that provide great efficiency at very light weight. They are ideal for small electric airplanes up to 5.3 oz. (150g). Featuring a slotted 12-pole outrunner design and special Curved Neodymium-Magnets that offer very small gap for optimal power and efficiency. [H=1]Specifications[/H]
A05 Outrunner Series A05 10S
Kv (rpm/V) 4200
Max Power (W) 25W
Max Amp (15sec) 5A
Max Efficiency 79%
Io (No load A) 0.5A
Rm (Resistance) 0.3Ohm
Shaft Diameter 2mm
Gearbox N/A
Motor Diameter 16.6mm
Motor Length 15.1mm
Motor Weight 7.5g
Built in Fan N/A
Max Rpm 25,000
Poles 12
Case Outrunner
ESC Timing 20-25deg
ESC Switching Freq. 8-16KHz
A05 Outrunner Series A05 13S
Kv (rpm/V) 3200
Max Power (W) 35W
Max Amp (15sec) 5A
Max Efficiency 79%
Io (No load A) 0.4A
Rm (Resistance) 0.29Ohm
Shaft Diameter 2mm
Gearbox N/A
Motor Length 15.1mm
Motor Weight 7.5g
Built in Fan N/A
Max Rpm 25,000
Poles 12
Case Outrunner
ESC Timing 20-25deg
ESC Switching Freq. 8-16KHz[H=1]Owner Description[/H]
This Motor is awesome!
[H=2]Owner Performance Observations[/H]
content
[H=2]Owner Recommend Modifications[/H]
content
[H=1]Photographs[/H]
[H=1]Videos[/H]
insert video links here
[H=1]See Also[/H]
WIKI link
[H=1]References[/H]
insert content reference links & footnotes here
[H=1]External Links[/H]
Kv (rpm/V) 4200
Max Power (W) 25W
Max Amp (15sec) 5A
Max Efficiency 79%
Io (No load A) 0.5A
Shaft Diameter 2mm
Gearbox N/A
Motor Length 15.1mm
Motor Weight 7.5g
Built in Fan N/A
Max Rpm 25,000
Poles 12
Case Outrunner
ESC Timing 20-25deg
Kv (rpm/V) 3200
Max Power (W) 35W
Max Amp (15sec) 5A
Max Efficiency 79%
Io (No load A) 0.4A
Shaft Diameter 2mm
Gearbox N/A
Motor Length 15.1mm
Motor Weight 7.5g
Built in Fan N/A
Max Rpm 25,000
Poles 12
Case Outrunner
ESC Timing 20-25deg
content
content
[H=1]Videos[/H]
[H=1]See Also[/H]
WIKI link
[H=1]References[/H]
