Anyone ever seen this?
I have a redwing 30cc MSXR with one of the old redwing power boards in it. It has a JR RG831B receiver in it fed by 2 1450mah LiFE for power.
When I first turn on the power, every servo on the airplane twitches even after connection with the TX. If I turn it off and back on quickly after that, everything works correctly. It does this every time I turn it on..
I have used these receivers in several other aircraft. Could this be caused by a bad connection somewhere? or possibly the power board?
What am I missing?
really just used the power board so that I could use the deans connectors. I picked it up on clearance for $20. I actually have been flying it for about 6 months without a problem. Just weird that it's doing that....I'll try it without and see what happens
Probably a bad solder joint, if it just started. Best to remove it completely. Modern day Rx are capable ofother demands of today's flying.
