Aerobeez 2015 EPP Lineup is now HERE!
Aerobeez
Hey everyone here on 3DRC! You may have seen them at AMA, or you may have seen us post about them in the past few months, but now there are finally here! The Aerobeez NEW 2015 EPP Lineup!
Our smallest model to date in a full fuse ARF is the NEW 38" Slick 540.
Black Model:
Red Model:
Specifications:
Wingspan: 38"
Length: 39" (without spinner)
Flying weight: 21 - 24 oz (without battery)
Recommended setup:
Motor: Hacker A30-16M
Speed Controller: 40AMP or above depending on motor/esc preference
Servos: Hitec HS-55, HS-65HB or 9G size
Battery: 3s 1000mAh to 2200mAh 20c
Prop: 11 x 5.5
Check out the full product listing for the 38" Slick 540 Black or the 38" Slick 540 Red.
We also have a return of our favorite EPP model from last year, the 48" Extra 330SC.
Blue and Red Model:
Purple Model:
Specifications:
Wingspan: 48"
Length: 48"
Wing area: 496 sq.in
Flying weight: 40oz-45oz
Recommended setup:
Motor: Hacker A30-14L V3 or Motrofly 2820-950
Speed Controller: Hacker X-55-SB-Pro
Servos: Hitec HS-5065MG or HS-65MG
Battery: 3S 2200 mAh - 2650mAh
Prop: APC 13 x 6.5
Check out the full product listing for the 48" Extra 330SC Blue and Red or the 48" Extra 330SC Purple.
And last but not least, we have the NEW 55" EDGE 540! This is now our largest EPP offering and a monster 3D trainer.
Red Model:
Yellow Model:
Specifications:
Wingspan: 55"
Length: 54.7" (without spinner)
Wing area: 617 sq.in
Flying weight: 60 - 65 oz (without battery)
Recommended setup:
Motor: Hacker A40-10S
Speed Controller: 70AMP or higher depending on motor/esc preference
Servos: Hitec HS225MG size
Battery: 4S 2800-4200mAh
Prop: 14 x 7
Check out the full product listing for the 55" EDGE 540 Red or the 55" EDGE 540 Yellow.
We are supper excited to have the new models here and we hope you are all to! Video content and Build guides will be added for each in the coming months so stay tuned.
Have a great weekend,
Team Aerobeez
Bloosee
Let the build begin. Should have the rest of the parts in a few days.
3dmike
Nice...I need a new foamie and love the full fuse idea...might just have to try one out...
You should! I have the 48" Sbach which is from a couple years ago and love it! Flies like a big gasser and is rock solid and durable!
Aerobeez
If you are thinking about it, any of the three sizes would be a great addition to a pilots hanger and 3D arsenal, but we love the new 55" that Bloosee post above. It is a beast with the slightly larger 55" wing span.
Check out our video from AMA this January here:
[video=youtube;JGCcGpCAwDM]https://www.youtube.com/watch?v=JGCcGpCAwDM[/video]
maxx4wd
Sweet...love the 5X" size...perfect for practicing and allows for some higher winds which I have a lot of where I currently fly (nothing outlandish but often times too much for the flat foamies).
