For Sale 40% TT TOC Katana LPU Pickerington, OH
Hazmat1
This is a very nice TT TOC Katana. Was told it was the predecessor to the Pilot Katana and Pilot parts fit. Has a very small crack in canopy, almost not noticed.
Very clean 40%. Comes with a DA150 with MTW canisters and headers.
All JR 8611/8611a's Digital High Torque Servos except elevators have brand new Hi-tec 7955's.
Rudder is equipped with an SWB rudder tray
Plane doesnt have 3 flights on it from new. Motor will still need broke in.
Come see it in person, located in Pickerington, Ohio.
Open to trades, but prefer cash.
Katana 40%
Item No. 4653
Aerobatic ARF Balsa TOC-40% TOC
Specification
Wing Span(mm / in.) 122”(3100mm)
Length(mm / in.) 111”(2820mm)
Wing Area(sq. dm² / sq.in.) 2672 sq.in.(172.0dm²)
Weight(g/ lbs.) 38.5 lbs.(17.5kg)
Motor
Engine 150 cc Engine Req'd
Radio 6-CH+12 High torque+2 High Speed servos Req'd
Content
Aluminum spinner
Fuel tank
Aircraft grade aluminum wing tube
Aluminum main gear
Rubber wheels
Aluminum stab tube for removable stab
Control horns
Heavy duty nylon hinges
Wheel pants
SAE bolts and nuts
Introduction
Our airplanes are built by craftsmen from the best quality balsa and plywood available. Careful consideration of each component material insures light weight structures that are strong enough to stand-up to the most extreme 3D maneuvers.
Each and every airplane is hand built to the highest quality standards. Utilizing proven interlocking building techniques combine with light rigid structures provide great flying airplanes. Components are built in jigs to ensure warp free surfaces such as fuselage, wings, and stabilizers. Proven competition designs for extreme 3D flight are the essence of the Thunder Tiger TOC airplane series.
The Katana 40% is another highly popular aerobatic plane, available in 3 different schemes. Built by craftsmen and covered with Ultracote ® in beautiful Thunder Tiger Team Scheme. The kit comes with all needed hardware and includes aluminum spinner, landing gear and all necessary accessories for giant plane needs. If you are ready to enter the gasoline-powered giant world, the Thunder Tiger giant TOC plane series is the right choice.
Features
Designed for precision aerobatics and 3D
Professionally covered in Ultracote ®
Strong, Light Weight Construction
Large control surfaces double beveled for maximum control throw
Canister and Pipe Ready!
Aluminum Wing Tube
Aluminum Stab Tube
Hardware Package Included
Great vibrant color scheme
20 to 30 hours of building time
capthis
I had one, but a flame out in a low High Alpha Harrier ended it. Flew like a giant foamy! Loved the plane one of the easiest to 3D planes I have ever flown!
Good luck with the sale!
