3D 30cc hazzbro extra
daman691003
So I was just messing around testing things. Is there a reason these holes are so far off They are all Cnc parts.
kwj48
Shouldn't be a big deal. Are those the anti rotation pin holes? The wings are attached with tabs I think. Do your wing mounting tab holes line up?
daman691003
Would u guys use this spar. So many setbacks with this kit. So there are two splits ones six inches long another is 3.
daman691003
I contacted seller he told me the spars are high density balsa. So I found another in the kit that should work. The one with split in it i can bend and the splits do not get any bigger. Anything I can do to use it. I think I found another piece within 10 grams of the other to use.
daman691003
The servo bays in the wings are tied into the ribs. But the ribs are very flimsy. I made some ply doublers and that helps a lot but weighs 20 grams a wing. Is that bad.
