Len
30cc
Hi gang.
A buddy( Rob) and I have been sitting on plans to build a giant scale Sea Bee for a couple years. In the mean time we bought a GP sales Sea bee kit an assemble it with an electric power system. Overall, its a good flying plane, but the lack of prop clearance limits the power and thrust you can have.
Moving to the scratch build project, we took a set of plans and had them blown up to the size we wanted.
Since this is a scratch build, not laser cut parts, no fiberglass cowl or floats, we'll be making our own.
The plane is being designed to accept the EVO 20cc motors. http://www.horizonhobby.com/20gx-20cc-(120-cu-in)-gas-engine-with-pumped-carb-evoe20gx2
They're on order now and I expect to have them this week. We already have an EVO 33 in a Hangar 9 Beaver and couldn't be happier with the performance, so its a no brain-er to use a pair of 20cc motors in this build.
The plan shows a single engine plane, so we'll be modifying to make it a twin.
First thing we're doing is building the wing. This will be the most difficult part of this build so we'll tackle it first.
The wing is a three piece setup, with the center section originally designed to stay with the fuse. We'll change it slightly and make the center section wider, incorporation the dihedral and the two motors. Doing this, the outer wing panels will simply slights right onto the wing tubes.
Off we go.
We cut most ribs out of 1/8 balsa, the rest are 1/8 a/c ply where the motors will attach, The panels will be capped with 1/8 liteply.
After that was accomplished, we clamped them all together with a ply rib on each side and touched up the tops and bottoms with a sanding block. The spar cutouts were also sanded to perfection while they were clamped together.
Setting the ribs aside, we designed out spar system and build the spar box. Our plan is to build an A/C ply spar, which incorporates a hollow for the 7/8 aluminum tube which attaches the outer panels. West Systems epoxy and a bunch of clamps will soon produce a bullet proof center spar.
The build will take time, we only get a couple evenings a week to work on the plane, so I hope you'll stick around and see what the results are.
LEN
RcAerotowing.com
Team Horizon
Off we go.
LEN
RcAerotowing.com
Team Horizon
