HRRC Flyer
		Hey Kelly,
You can do what my friend does to an airplane he doesn't like. He takes it to his band saw. . .
Hey Kelly,
You can do what my friend does to an airplane he doesn't like. He takes it to his band saw. . .![]()
Sweeeeeet! Look forward to hearing how they work out for you. Like the helical gear concept.
.Bitchin'. I like....Back when ARF's where first coming out it was "expected" to have to do some fiddling with the aerodynamic set up of the model. But with todays modern manufacturing and building there is no excuse for a an ARF company to completely blow a incidence setting. I really believe that I was used as a recycle bin. They won't see any more of my money directly. I will use the good vendors here in the US. If they truly want to survive they will have a good customer support ethic. I am very pleased that things worked out though. I'm starting to really like this plane now.
Now here is a company I have had great success with dealing directly..........Just got a box full of Bad Ass.....
View attachment 50958 View attachment 50959 View attachment 50960
Lemme know how you like those servos. I tried to order four from tdrc but they didnt have enough. I was gonna try the bms-2109s.Back when ARF's where first coming out it was "expected" to have to do some fiddling with the aerodynamic set up of the model. But with todays modern manufacturing and building there is no excuse for a an ARF company to completely blow a incidence setting. I really believe that I was used as a recycle bin. They won't see any more of my money directly. I will use the good vendors here in the US. If they truly want to survive they will have a good customer support ethic. I am very pleased that things worked out though. I'm starting to really like this plane now.
 Ok I got 12 flights and 16 engine starts on the DA 70 with the custom muffler. Some post flight inspection has revealed only a wheel collar (cheap stock aluminum.....note to self.....throw them away) on the right wheel came off causing some minor cracking and chipping of the paint. The connections from the header to the muffler are holding up well and absolutely no gooey mess any where! Clean as a whistle! I have been having about a 1/4 tank of fuel left after 8-10 minute flights. Next time out will get tach and thrust readings for performance increase if any. It has consumed approximately 1 gallon of gas.
Looks great Kelly. I have to be honest and tell you, I am really regretting selling that 70 to you. Think ya might just wanna send it back? NAAA? Yeah, didn't think so. I am very happy all is going well with the Jtec custom muffler and the 70 twin.Ok I got 12 flights and 16 engine starts on the DA 70 with the custom muffler. Some post flight inspection has revealed only a wheel collar (cheap stock aluminum.....note to self.....throw them away) on the right wheel came off causing some minor cracking and chipping of the paint. The connections from the header to the muffler are holding up well and absolutely no gooey mess any where! Clean as a whistle! I have been having about a 1/4 tank of fuel left after 8-10 minute flights. Next time out will get tach and thrust readings for performance increase if any. It has consumed approximately 1 gallon of gas.
View attachment 51220 View attachment 51221 View attachment 51222 View attachment 51223 View attachment 51224 View attachment 51225 View attachment 51226
