What did the final weight come in at on yours terry? @kwj48 sbach65 profile is around 9 lbs and it may not be over powered but it has enough power to keep it out of trouble with a DLE 20. Can't wait to see what my stix60 profile does with the DLE 20 as it should come in around 7lbs.
8lb 10oz RTF with single 2200 LiFe pack. My servos are metal case Savox 1283's so without those you could loose about 2-3 oz. Everything else stock. One switch, ignition cut-off, one battery, small RX. Nothing else to shave weight. You definitely can't take your eyes off it for long, but I understand that is the case with most profiles.
.      Be sure to get a video
