By the way.... I am ordering a replacement Purple Edge Friday. I am certain I may need it....eventually. Bwaaa haaa haaaa
lol It's a pic from Chief, but I do use Meguires spray wax, makes clean up easy breezyBEAUTIFUL BEAUTIFUL.. What type of wax do you use. WOW. HAD TO PUT SOME SHADE ON AND. ITS 2.00AM
Bart just holler, talking to @emtp275 these things go together super fast.Don't you guys know that "it isn't easy being green".
By the way, I am glad that you guys have worked out the science on the canister install on the 540 so all I have to do is order parts and then get @ChickenBalls and @emtp275 to install for me!
Rob this is from our phone call bit ago, meet @PlaneNutz1By the way.... I am ordering a replacement Purple Edge Friday. I am certain I may need it....eventually. Bwaaa haaa haaaa
Ohhh crap ill have to trash it nowNO! Don't cut them off!!!! The whole damn plane will fall apart!
But I see you cut the BS out of the way LOL im lazy and dont want to make carb adjustments in the needless wood and cowlI had these pictures on my phone I took through the front of the cowl. I used balsa triangle stock on the front edge. Adds a little strength without much weight. Plus it looks pretty.
View attachment 25396 View attachment 25397
I cut mine off. I have a friend that did not cut them off either of his and honestly, it makes the firewall look really cheap and low quality. Just my opinion.@Jetpainter did you cut the extra ends of the motor box off after you mounted the fire wall? I cant find a reason not to cut that off to clean things up but I was interested if any one else did that.
