I was posting the OP. But! I have used it there also and then drill and tap for 4-40 x 3/16 button head screw to each end so your pipe or can wont turn with vibration. Also wrap with Teflon tape. Here is a example but not a gasser. The exhaust temps are higher though because it is a 4 cycle.
Yes thanksPerhaps, but the Viton is good to 400F and has shown zero degradation in this application. Silicone is not gasoline resistant, but Viton is.
Dimes, what kind of hose are you using to couple to the canister there? I have a situation with a head for my DLE85 and was thinking about a high temp hose with a braid on the outside or something.
